2004 CR250R Won't Start
My bike is killing me.  Bought bike barely used, rode it for a year, Son got really sick in the hospital for 7-1/2 weeks last summer so bike was in storage for a year.  Mixed new gas and it started up second kick and then revved up to a very high idle so I had to kill it by putting it in gear and letting the clutch out with the brakes on.  I figured it was a carb problem after sitting for so long so I pulled off the stock Mikuni TMX 38 10A (it has stock jetting except the Pilot, 40 Pilot Jet/420 Main Jet/Stock Needle on 2nd clip).  I disassembled the carb and soaked the body in Berryman's Carb Dip Solvent overnight, washed it out in the deep sink and blew out all the passages with compressed air.  I cleaned and re-oiled the air filter.  Validated that I have flow out of the fuel tank to carb.  I reassembled the carb, replacing the Viton needle and seat, float bowl oring seal, pilot jet 32.5(new), and main jet 420(new), Air/Fuel screw 1-1/2 turns out.  Bike wouldn't start at any A/F screw setting.  Pulled the plug, it had a BR8ES in it that looked, as expected, based the on richer jetting it was pretty black.  Replaced with a new BR8EIX.  Pulled out my handy-dandy spark tester and it had a big fat blue spark.  The motor has very few hours on it and has plenty of compression.  Still won't start.  Inspected the Vforce V3 reed valve block.  No reeds chipped.  I figured maybe the high idle and rich jetting on the Pilot Jet may be due to a leaking left side crank seal so I replaced the crank seal and went to the stock 32.5 Pilot Jet.  Still won't start.  I shot ether in the airbox.  Still won't start.
I am at a bit of a loss right now.  Here is what I am gonna do this weekend ANY ADDITIONAL IDEAS WILL BE MUCH APPRECIATED!
Check Float level on Carb
Change out the reeds
Replace clutch/water pump side crank seal
Clean fuel tank valve screen
Replace fuel tank breather hose
Compression check
Thanks in advance for any help you folks can provide.  Never been so stuck before.
start with the comp test.
also remove the exhaust and visually look at the piston and cylinder walls.
Go back to the spark.. Just because the spark tester showed it working once, it might have a break in the coil wire somewhere, and worked in that specific position.. Even the plug, I would grab a second new one to eliminate the chance that the new plug is no good. Check for the spark right at the plug tip, by resting it on the head, maybe the cap is no good.. Also check that the plug is seeing fuel when it's kicked over by smelling it for fresh gas in the cylinder
Good call on going back to the spark.  Coil/plug wire assembly appears to be bad.  Got one on order from RMATV
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
