2001 yz 125 bogging problem
so i have a 2001 yz 125 that was running good until it started bogging really bad. before all of this i rebuilt and jetted the carb, new cylinder and head, new top end. once i noticed it a little bit later i took out the carb and cleaned it out to make sure nothing got into the jets. it was fine but no diffrence. any ideas?
You didn't jet the carb richer did you ?  A re-build motor typically runs richer.  May not be your problem, but it's worth a go.
For reference, I've got a 1997 YZ125 (which I think is basically the same thing).
1 size leaner main jet, lowered the needle 1 clip, 1 size leaner pilot jet, air screw 1 1/2 turns out.  Bike funs flawless !
I did a rebuild on my 1999 yz125 and found the same bogging problem. I adjusted the air fuel mixture screw and it solved the issue.
Edited by slaketanley
2001 was the first year of the bigger size carb I believe 52mm. Stock jetting was off on mine I had to play with my jets til it was just right
  • Similar Content
    • By Mikeybabbel
      Hey guys, I just picked up a running 03 yz125 a few weeks ago and upon tearing down the top end, I noticed the cylinder head looks a little beat up. Is it possible to just clean it up or am I better off just buying a new one? Thanks guys.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
