Checks before heading out?
As I'm very new to this sport I don't know a whole lot about bikes. Over the last few weeks Ive done my fair share of research, where different websites/pages all give you different guidance.
One main thing that I would like to know is what checks should every rider carry out before taking their bike out?
Ive read my manual (KTM 250SXF) back to front but as I've never had a bike before, a lot of it is maybe a little too technical... Although I'm sure ill pick it up over time.
Any help/guidance would be appreciated.
Before each ride:
Fuel up
Check and adjust tire pressure
Check air filter
Check engine oil for four strokers
After each ride:
Lube chain
  • Like 2
what i REALLY need to start doing, check spokes once a week or month depending on how often you ride. I ride gnarly rocks fairly quick and so i have a toruqe wrench and need to use it more, i know they are loose right now so thanks for reminding me.
Before each ride:
Fuel up
Check air filter
After each ride:
Lube chain
You forgot chain adjustment.  Check the freeplay.
I run o-rings.  I check 'em occasionally but I usually get two years out of them before they stretch.  I guess there are still people out there that still run unsealed chains for some reason though.
Before each ride:
Fuel up
Check air filter
After each ride:
Lube chain
Thanks gents! I'll need to pick up a tire gauge tomorrow as its something I don't yet have!
Lee
Actually, everyone I know does not run an o-ring chain.  Everyone runs regular chains here once they replace the stock one. ;)
Inexplicable.
Actually there's a very good explanation.  Most guys I know like to replace the sprockets at the same time they replace the chain, so it would be crazy to throw out a chain that costs twice as much.  I haven't run an o-ring chain in umpteen years, I just take good care of regular chains.
That's fine methodology for an unsealed chain that wears quickly regardless of care and lubrication.  O-ring units do not stretch until they fail so you can replace sprockets as needed without replacing the chain.  I often replace sprockets two or three times by themselves without servicing the chain.
The last one I put on went on with a set of Ironman sprockets.  These things don't really wear out either.  Last one I had lasted until it exploded but the teeth still looked good.
Most of this has been covered but I'll throw in my 2 cents.
Tire pressure gauge - I've got a small digital one I carry in my pack and a floor pump in my van. I check before every ride. Tend to stick are around the same PSI frt/back during the dry months but play alot with mostly the back PSI when is really wet and snotty.
Oil - I run an hour meter and change my oil/filter MAX every 10 hours but I check for level and colour before every ride. If you notice you are lossing oil. Don't ride untill you sort it out. Then if the oil starts looking really dark I will change both sooner than 10 hours.
Brakes - Do a quick check before I leave the truck.
Throttle - again quick check it's not sticking when starting.
I tend to wash my bike every couple of rides and give it a good visual once over once it's clean. IE air filter, chain, brake pads, damage etc.
Now off topic but it's Friday nite and I'm a bit bored - As far a chains go, I was running an o-ring but when I did my last full drive replacement (over 2 years ago) and my local shop guy suggested I try non-o-ring. His theory is that you get a better response with the non-o-ring. Honestly I don't think I can real tell the difference BUT I'm anal about keeping it clean and lubed and my Renthal drive train still looks and functions like new
Check your chain too.... An if lube won't take the kinks out then get a new one when you can because I took too long an it snapped on me last night about mid night after work. Had to get a lift home unfortunately.
Snapping a chain can crack your cases easily when the chain wads up, or it can lock the rear wheel causing an accident.
Just something to keep on mind. I got off easy fortunately with just a nickedscratched case.
check spoke tension
throttle cable (make sure doesn't stick)
rotors/sprockets for loose bolts
air pressure
fresh air filter
check oil
lube chain & check slack
Also wash after every ride... I know it's the last thing you feel like doing after a good ride but it will keep your bike looking fresh and will be easier to clean if you don't wait till the mud dries up all the way through
Edited by problem_child
  • Like 2
Make a written list and check it off. Otherwise you might ride in golf shorts like I did last summer....
I have written lists, converted to PDF files, saved on my iPhone.
When prepping, I start with my feet and vocally check off all the gear I've packed and need to wear...like a pilot flight check does.
check spoke tension
air pressure
fresh air filter
check oil
Great points. Also, washing then drying the bike....you spot broken or loose things you'd otherwise overlook.
Lee
I just got, from a thumper recommendation, the slime digital. It is the one that does psi up to 150 psi. I use tubliss....so I need to know the high pressure too.
Well, this sucker only cost about ten bucks! And it works really good. A high psi gauge can go for seriously big bucks. I got mine at oreilly s auto parts.
Most of the general stuff has been covered by others here, but I also like to quickly go over the bolts (body, engine, etc..) to ensure none are loose. If you did any maintenance after your last ride, remember to set any settings to what you prefer. Also remember to remove your plugs before trying to start the bike. I've forgotten to do that a couple times and its quite embarrassing.
Most of the advice here is good, some I don't do quite the same way.
Regardless, I check soon after a ride so the bike is always ready to go.
I work for myself and the Coconino is out my back door and want to be ready when the urge strikes me.
Odo reset
Tire pressures OK
Fuel topped off
Oil change <30h
Oil and coolant level OK
Skid plate on/secure
Bolts tight - Shifter, seat, bars, plastics, handguards
Sprockets/chain OK
Light check - Headlight, turns, running lights, brake light (from front and rear brakes)
GPS: Waypoints loaded, CityNav map loaded, RAM-mount/arm, Batteries OK
I ride daily, so if something's amiss I usually correct it that evening rather than putting it off till my "next ride", because that's probably the next morning.
For my daily commute/around town trips I usually just fire it up and go.  Do a more thorough check before I head further out of town or into the dirt.
Also a big +1 for making a list - I have a "packing list" that lists every tool I carry in my tool wrap, items in my pack, things I wear.  Makes it easier at the beginning of the season to pull up that list, grab this, grab that, that thing goes in my pack, oh yeah I need this tool out of the garage... and not forget stuff.
  • Like 2
it may seem anal but ya - I have a book where I log all my maintenance and might stick a few reminder post it notes on the bike before the next ride.
Then for my multi day dirt bike/camping trips with buds, I put together a bunch of different lists in Excel/PDF. Before the trip I check off all the stuff I'm bringing then shoot it if to my buds so we don't all end up bringing for example 4 chain saws or 2 BBQ's etc. Then just basic cooking and food.
