honda crf 150r clutch problems
hi
I have a honda crf 150r for minimoto
we modified the engine with
cylinder works 159cc big bore kit
fmf megabomb - powercore4
boyesen quickshot3
Suter slipper clutch
this winther we mounted the big bore kit and new Prox clutch plates including steel plates
but the clutch is slipping as f.ck
first we tried with the big diskspring 1700N... had no difference then we tried some different oil.... no difference
i talked with some friends of mine and they had no problems at all, and they are using the stroker crank to!
no parts worn out i think we tried everything but its still slipping
last year i had no problems at all
do you guys have a guess whats wrong
im waiting for Barnett clutch plates and a diskspring about 2400N
do you guys have experience with Barnett plates?
kind regards
Thomas
sorry about my english im from Denmark
Hey make sure you are using motorcycle oil, or dirt bike/Atv oil. Anything but car oil. The additives inside of the car oil not only destroy the clutch but obviously make it more slippery
also try adjusting your clutch cable to make sure that there is at least one eighth of an inch of play on the tip of the clutch lever. If not then the clutch will be in semi engage position which is also bad for the clutch.
