Engine rebuild: Grease or no grease outside of main bearings?
When installing the main bearings, is it ok to put a little grease on the outside of the main bearings?
I will use a press and freeze the bearings, but to ensure they install nicely I'm wondering if a dab of grease is ok, or if it may cause the bearing to spin in the case?
They should go in without anything
If anything I would use what ever oil you are using in gearbox
