Stock clutch perk
Hey all, I am currently installing an RSC clutch lever and perch and am just wondering what exactly this is and what it is for on the stock perch? Is it ok to remove and how so? Thanks. ImageUploadedByThumper Talk1461378397.955558.jpg
It is the clutch activation switch. You can remove it; however, you will have to splice the wires together to disable the clutch switch. Doing so... Better remember to put bike in neutral or clutch in every startup. I disabled mine. Search for more info
Thanks a lot. Found a video showing how to disable. Looks like it should be a pretty simple task. Although I say that about most things bike related promptly before screwing it up, ha.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
