Manual Cam Chain tensioner vs Mechanical
I'm leaning towards the manual, as the design makes me think it will last forever.  As opposed to the ratcheting mechanical, which the teeth may strip over time from engine vibration.  The bike is a 2012 ktm 250 xcfw.  The stock hydraulic unit is shot at 170 hrs, the mechanical unit I'm looking at is from Dirt Tricks.  Anyone have one of these installed on their bike who can speak on how long it will last?  Thanks
I read a lot about the manual adjusters and I do know that many guys use them successfully, but my honest opinion as a mechanic for many years who has been countless motors these things make me cringe.  Cam chain tension is pretty important, and I believe you are much more likely to screw something up by having the adjustment on one of these be off than the chance of some catastrophic engine failure due to a stock tensioner coming apart.  The worst I have ever seen happen with a stock tensioner is some noise, which is obviously fixed by a new tensioner.  Even a little too tight on a manual adjuster can be disasterous for an engine and IMHO not worth the risk.
Again, this is my own biased opinion but I have spent a couple decades first as an auto mechanic and then bike mechanic (only do it on the side now) and I owned two retail/service shops for 5 years in the middle of it.  I always tout OEM parts for just about everything.  I was fairly young when I started my shops and was all about aftermarket everything, but after selling and installing aftermarket stuff for so many years I will go OEM on just about everything.  Motocross bikes are not like a Honda Civic, these machines are built with the use we put them through in mind and while the factories and engineers do sometimes get something wrong, overall you can usually be assured that that engineers that design these bikes for a company that has spent decades and millions of dollars and has millions of cumulative hours of their products being used in the real-world as feedback with which to design their products has got it right.
I know plenty of guys run these successfully but I would not touch one with a ten foot pole.  I have taken out hundreds of chain tensioners during valve adjustments, top-end rebuilds and motor rebuilds and I have never seen the teeth stripped on one of these before.  I always recommend a new cam chain and tensioner as part of a routine top-end rebuild as they are wear items but see no need to deviate from stock on these items.
How difficult of a job is properly installing a manual cam chain tensioner? Harder than doing fork seals?
How do I tell if the cam chain has been over stretches and needs replacement? How far should I be able to pull if off the teeth of the sprocket before it needs to be replaced? Thanks
Edited by idratherberiding
Actually on my '08 after freshening up the a top end, I went five laps and at the end of a bunch of whoops it let loose.  After taking it apart I found there was no oil in the hydraulic tensioner.  I chalked it up to something I did wrong and immediately bought a manual tensioner and it worked great.  For me, the trick was to only adjust it with the valve cover off making sure there was a slight amount of chain tension. I have no idea what the problem was with the stock tensioner but have heard I am not the only one that has had that happen.
This topic is like the "which engine oil" is best... various opinions.
I ran a manual cam chain tensioner on my 450R all last season, I checked it after every race and most hard practice sessions. For trail/woods guys they may be fine (set/adjust and forget).. but if you're twisting against the limiter on a fairly regular basis, you should/need to check it after every race which is a total pain in the ass..
I just installed a brand new OEM tensioner back in my 450R for this season, and I know some factory race teams do the same thing. I think the stock/OEM tensioners that you hear all the horror stories failing have been in the bikes for 100's of total hours. I will change my OEM tensioner at every top end. Very cheap, and takes all the guess work out of it.
That's just me...
I hear that. If it were a 40 dollar part, ID do the same thing. But for me it's a 120 dollar part. I'm still undecided on the dirt tricks or manual. Everyone is making great points. I'm sure the dirt tricks ratcheting unit is much better than my OEM hydraulic unir, which was shot at less than 146 hrs
The stock/OEM tensioner is $58.22 for 2009 450R on Motorsport.
Cheap insurance, and easy to replace at every top end rebuild, or once per year whichever comes first.
Pro's and cons either way.. I personally like the fact of "install and forget about it".. I prefer peace of mind over guess work any day.
Ty for your input
  • Similar Content
    • By element9
      The story begins with simple installation procedure of a BIG BORE kit that we ordered from USA . The manufacturer (CYLINDER WORKS) and the dealer send us the correct kit and so far so good ! .
      The bike is a KTM 250 sx-f ,2011 model and bellow there are some photos for you, just to see how careful I am throughout the process .
      .. .. .. .. I change the valve seals and the exhaust titanium valves and springs with the PROX steel kit and make a little polishing on the intake and exhaust
      Put the cylinder-piston on and always with guidance from workshop manual and correct clamps...
      Until now we where happy !!! We start the engine ,and everything seems to be ok!
      Began to make the first ride and…… DISASTER !!!
      The engine start bleeding OIL from the hose-tube !!!!!!!!! I thought its normal if it is one-two drops but unfortunately didn’t STOP .
      We did one more ride to see what happens and still BLEEDING. Back to the WORKSHOP.
    • By Dutch84
      I got about 6 months on my 350 xcf-w. I ride a lot of tight, rocky,rutty, slippery single track in South west PA. The only things I've added are suspension, bark busters, skid plate and disc protectors. I purchased a trail tech mapping switch but hesitant to add it as I heard the dealer needs to unlock the ECU and am not sure how much of a benefit it will be. I have a Scott steering dampner I'm going to add. I'm also looking at exhaust options for my riding conditions. What do you guys think about the items listed and what suggestions do you have?
    • By OffroadMT
      I am purchasing a 2012 KTM 350XCF after wanting one for a year and finally picking one up in December. My question is what are some good things to watch for on this bike as far as initial set up and good Mods to improve bike ? My plan is to add a skid plate, hand guards and muffler with the possibillity of changing the header pipe and a Rekluse EXP would be nice as we ride mostly single track mountain trails with some rocks . Any good thoughts and suggestions would be appretiated
    • By riyaadhd
      hi TT users
      i have a flat 11 acre property 20 mins from my house. the property has a pond in the middle of it.
      i am wanting to build an mx track on there, What equipment/excavators will i need to hire. how will i go about constructing the berms, whoops, table tops and jumps. And how can i keep out unwanted riders. How much dirt will i need?
      i would be great if any ones knows track designers and cheap dirt and machine hires. (Dont have much $$ to spend so free or cheap dirt and equipment would be GREAT )
      i am in Brisbane, qld, Australia. Any quarries i can phone to dump free dirt
    • By 13KTM450SXFTRLRDR
      I just purchased a brand new 13 KTM 450SXF over the weekend and decided on Sunday that I would go for a break in trail ride with my dad and a few freinds. I put an hour meter on the bike before it was ever started and had .3 hours on it before the first real ride. During those .3 hours I started the bike and warmed it up and then completely cooled it down two times ( changing rpms and second time rode it around went through the gears and such). I did notice that the cluch seemed a bit noisy when disengaged and in neutral idling but figured it wasnt a big deal because I also heard from others on youtube videos and sounded no different from there's. bike is signif. quiter with clutch engaged(pulled in). So we loaded up and headed out to the desert, immidiately I could tell that I was going to love the bike, I have a 11 KTM450 sxf that I also absolutely love, but it seemed to be getting long in the tooth (145hrs 1 piston and ring total maint!!) and I heard good things from shootouts about 13 and got a good deal so got it. It feels so much lighter than the 11 and handling was amazing!! plus amazing smooth low rpm pull just like my 11 followed by super responsive and super power as every rpm comes up to stupid fast top end. I was loving everything except that the bike was running pretty hot at low speed working the bike like we do every weekend in the tighter technical trails, to the point where I had to shut it down a few times and let it cool was spitting barely out of the overflow!! let it cool and continue. I figured that the bikes fi mapping was way too lean at low throttle position/idle settings. So overall ride goes great and never notice any clutch issue except that its super smooth and amazing light(as light as my 11 with mountain engineering lever and bigger bore master cyinder!!). Next day I decide its time to change the break in oil and wow!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Oil comes out like black water with the smell like I lit the bike on fire!! I work on bikes and cars and whatever I can get my hands on on the side as a mechanic and so I new the smell was that of a fried clutch so I opened up the cover and wow!!!!!!!!!!!! again, clutch steel plates are just black and blue as can be and the fibers are dark fried look!!!! So sad I love the bike but ive pushed my 11 wayyyyyyyyyyyyyyyyyyyyyyyyyyyyy harder for over 90+hours and changed the plates just because of the time on them not because I actually needed it, and this 13 has only 2.4hours on it with only maybe 1 or 2 full throttle blips and tried to be easy on it overall!! pretty silly I called the dealer and they said never had this type of issue before but then called rekluse and they said they havent even made a clutch ass. for the sxf or xcf yet because they arent ready to due to reliability issues!! funny because its exact clutch as 450xc,xcw,exc and 500xc,xcw,exc and all the 13 two strokes. I believe that the 250psi belleville washer is not sufficient for the bike. not enough pressure but crazy I didnt think I was pushing it!! Scariest part of all is now this bike with 2.4 hours on it has had shit watery fried oil and clutch debris floating throughout all those nice new parts and nice new soft crank plain bearings and tranny, etc etc!! Even if its fixed im worried about the engine now!! Hopefully KTM will realize the problem(which rekluse says that they no whats going on and they are working on it) and warranty the whole damn engine for me. I guess I get to cross my fingers for now, would have kept that awesome 11 if I only could have known!!!!! :( PS-apperently the enduro race team rider (forgot his name carrelli or something) could not complete a race with this clutch and went back to his reliable 12 because of the issue!!
