2003 450R hydrolock
Hey everyone first post, getting a really good deal on a 03 450R. It's street legal but has some issues, last time it was ridden it was dropped into a stream. He said it may have been hydrolocked, and hasn't been able to be started since.
I've done some research but is there a good process to troubleshoot the engine or where would you start if your not 100% sure of the history?? I'd like to take the time and do it right.
Also after doing some research it looks like this year had was prone to some valve issues, is it possible to update the head to a newer configuration? Or just better to stick with the current setup.
Thank you all in advance, can't wait to get out on it.
Edited by CThumper
Can only comment on head fitment. Any 02 to 08 will work. In 06 they improved the seat material and the 06 use the same valves and cam.
You could just send your head to Pro1 with new OEM parts and get their copper alloy seats, guides and valve job.
Or, you could just buy a new complete head from Big Bore Thumpers.
Either way it's close in price ($550).
Thanks, I thought I had read the intake valves were prone to failure on 2003 and prior, if they are all interchangeable what makes the 2004+ better? Or am I wrong??
Edited by CThumper
06 seats are softer. Prior to 06 the hard seats would cup the valves and eventually they would zero out (no clearance).
Never heard that 04's were better but I could be wrong.
