Stock exhaust cleaning?
Was looking for a good way to clean out the stock baffle on a Yamaha blaster there is a bunch of unburned oil in there that I don't want shooting out
The safest way is to use a non flammable degreaser and you should be done after a few hours. What I have done, but do not recommend, is scrape off all the gunk that you can with a wire brush, soak the baffle in a solvent, spray down with some carb cleaner and let air dry. Do not scrape when using solvents, as a spark could cause a fire.
Once dry, use a pick or similar tool to finish the cleaning and then reinstall.
Yea I've herd about setting the thing on fire and doesn't sound appealing to me lol, I'll go with what you said on non flammable and then hit it with carb cleaner thanks buddy
