Yz125 Power Valve Acceptable Wear?
Check clearance between piston and powervalves.If they wear enough they will eventually hit piston. I want to say you should have .015" clearance but not possitive its been to long. If they need clearanced just grind then down lightly untill back in spec. They will eventually start vibrating the pins out if you put enough hours on them.
