KTM 2 Stroke Big Bore Build
Hi Guys.  I have recently installed a big bore kit (300cc) on my 2011 KTM 250 XC W.  I am having some issues.  Since I have done the modification, I am going through piston kits.  The bike has only done about 80 hours on it since the rebuild, but I am already on a Gr1 piston kit.  The bike seems to run very hot.  I have now installed an external cooling fan on the radiator.  I have not changed the carburetor jetting sizes, but I have changed the needle position - now position 4.  The air screw is set to 1.75 turns.  Does anyone have any advice?  Cheers. PaoloC
Generally when you put a larger piston in with the existing carburetor your jetting needs go towards smaller jets.  Greater vacuum puts a stronger "pull" on the existing jets,  and draws more fuel through them.   My guess is your head work was not done right.
When you refer to "head work" not being done right, what does it mean and how can I do it?
