Which subframe E or S
I have just purchased a newer DRZ400S but have an old DRZ400E As far as I can tell the S and E Australian sub frames look very similar the E has an extra mounting point for the muffler which I think is good as I am taking the after market Muzzy muffler from the E and putting it on the S it has springs joining the muffler so the extra mounting point is good but no rubber points.
The S subframe has one muffler mounting point which is rubber it might make a difference I would need to get a peg eliminator which seem hard to source.
I am leaning towards putting the E subframe on the S which has worked with the Muzzy exhaust and not worry about the S rubber mount?
Usually it is the midmount that is different between the models . Didnt realise it but the aussie E might have a similar subframe as the S/SM . Craigo and chooken should be able to tell you , I only owned an SM , greg
