2009 50 sx will only idle at high revs
 I have picked a 2009 KTM 50sx for my son and it will only idle if the idle screw is turned way up.
   it will only start if the choke is on either hot or cold
  Any ideas ???? before i rip into it
Ya my sons is finicky too it's the pilot jet did you open the air screw at all?
i haven't had a good chance to look at it yet.
turned the idle down and all it wanted to do was die and stop
Close the air screw in then back it out 1-1/2 turns if the bike still idles high open the screw quarter incriments. My sons is the same way it needs to be rejetted pilot jets to small.
ok sweet as....... i'll give that a try first.
once it does die...it will only re start with the choke up
It's the jetting they may be dirty. I'd bet the carb needs a good cleaning and air filter.
that was my first thought......air cleaner is dirty.
haven't had a chance to pull it a part yet....hopefully i'll get a chance over the weekend
I would check the stator also. I had problems with my son's and the stator was going bad. It would run but not idle and it would cut out once on the gas.
