YZ 125 suspension questions.
I currently have a 2011 YZ 125, I recently had the stock springs put back in the forks and rear shock. I would like to bring the all clicker settings and sag back to stock and then do some fine tuning from there. If anyone knows all the stock clicker/sag settings please let me know!IMG_0013.JPG
Infos from my 2010 YZ125 service manual:
forks :
spring rate: .42kg/mm
outer tube oil volume: 333cc
compression: 13 clicks out
rebound: 14 clicks out
shock :
spring: 4.7kg/mm ('10 had a Titanium spring, '11 should have too up to '13?)
nitrogen: 142psi
sag: 90mm to 100mm
high speed compression: 2 turns out
low speed compression: 13 clicks out
rebound: 11 clicks out
Stock spring rates are in the ballpark for a 140-150lbs rider.
Edited by mlatour
forks :
shock :
nitrogen: 142psi
sag: 90mm to 100mm
Thank you very much!
