There is no reason to change jetting if it ever ran well with the jetting you have now.
That plug is not fouled, if it is dry.
More likely you have a stator or cdi pick up issue causing your spark to vanish over time.
That plug looks like it might be showing signs of burning oil, which means you need to do a leak down test.
