2006 yz450f and vortex x10
The stock jetting, or probably the MXA testing jetting specs, will work just fine. Search MXA jetting 2006 YZ450 in google.
The main jet might need to be a bit larger due to the pipe.
All other jetting is air density related, so it depends on where you are.
Your airbox does not need to be opened up, as it is fine stock.
The Vortex has nothing to do with jetting. It's a programmable ignition, so you can create your own ignition advance curves.
Got all the info I need now Thank you for that
You were spot on No jetting needed for the cdi, so I don't know why people are re jetting when using the x10
 Got the jetting specs from pro circuit to run the pipe
B
