Kx 250 crankcase damage help?
20170316_192302.jpgboth crankcase's have damage, scared to run them I'm afraid they might get worse. Other side has hair line Crack as well and has more damage..anyone know where I can get them fixed. I took them to local machine shop they wouldn't work on them because there to small. Don't wanna buy used cases flea Bay is to expensive any adive?
Your local welding shop could fix them. File/grind yourself just have them weld :thumbsup: looks like someone pry'd apart with screwdriver usually how they get broke like that.
Edited by Motox367
This picture doesn't do it justice, the rod acutely push that section in...not much but enough to crack both cases in same place...Im gonna try different machine shops but was hoping there was a machine shop anyone on here could point me to that specializes in this..thanks guys for advice tho!
Search throughout the entire TT foum search function to see who others are using, as this is not really a Kawasaki problem, but a general dirt bike problem. You will get more answers that way.
