TTR 230 Dies When Pulling Clutch In
When I pull the clutch in on my 2007 TTR 230 from anything 3rd gear or above it dies. Have to give it some throttle to keep it alive. Anyone know why this is? It runs and idles normally otherwise.
Do you mean the bike just does not have power or it just shuts down?
I would rebuild/clean the carb.  Check compression and valve lash.  Change plug.
Did you use OEM parts or aftermarket?  If aftermarket, what product?
Odd that it would run fine until 3rd gear and the stop.
If you can rebuild the top end then you can check the valves if you have feeler gauge and tapit wrench.  They are easily accessed on this bike.
