Anybody know how to remove stock muffler internals
Hey, I'm trying to get the end cap out of my daughter's CRF150R so I can either fab a sparky screen or install a Pro Moto Billet.  But, I've drilled the rivets out and I'm danged if I can get the end cap to separate from the muffler shell.  Anything I'm missing or is there a trick or what?
 Thanks!
Sometimes when you drill rivets, the heads will pop off but the rivet remains in the hole. If that happened, you need to make sure you punch the rivets through the hole. In addition to the rivets, there should be a sealer that you'll need to work through to get it removed.
You will most likely have to separate it at the mid pipe first and then put something through the can to push the end cap out.
Yup, thanks all! Finally got it apart. For some odd reason, I expected it to separate closer to the end cap than it does. Total pain in the...
