Is it normal for the front sprocket to have some play in it?
I replaced my sprockets and chain. Before I pulled the old front sprocket off I noticed I could wiggle it a bit on the drive shaft. When I put the new sprocket on, it does the same thing.
Is this normal?
Not normal, I've seen it once before and the guy had installed the outer nut on backwards.
Its weird because there isn't an outer nut. The sprocket slides on and then there is a clip that goes on and the clip bolts to the sprocket with two bolts.
