Clutch Slave Cylinder Bolt Stripped - Options for Repair
I have a 2014 KTM 250 SX. While getting it ready for the year (changing clutch fluid) I found the bottom bolt on the slave cylinder is stripped.
I'm looking at my options and if anyone has had any luck fixing these before? The options I have came up with so far are below.
I could try a helicoil but there isn't a lot of meat on the case in that area and I am afraid of ruining the case if I start drilling. New case is $600 plus the cost to essentially rebuild the engine in the new case.
Loctite makes some thread repair epoxy that might also work. This bolt doesn't need a lot of torque on it so this might hold.
Another option I have considered is the threads deeper in appear to be intact. It only has about 1/8inch of good threads available, but I could put a stud in with red loctite and then put a nut on the end. Again this bolt doesn't need a lot of torque so this might work.
Any insight or help from those who have more experience with these KTMs would be appreciated.
You could drill a little deeper in the case and re thread it but you will have to find a longer bolt. I think it's 6mm Be careful not to drill too deep. You don't need a ton of thread for the small amount of torque on those. This isn't the best fix but it is quick and cheap.
divot is right, give that a go first, drill another 5mm or so and make sure you dont overtighten the bolts.
other option would be to re thread it to m7.   m7 quite rare on bikes but i can assure you they exist, there will be enough room for that.
I like your idea of a stud and nut using the threads that are left, but I would first try just using a longer bolt with some blue locktite. Drilling the existing hole to accept a larger diameter bolt seems less risky than going deeper. If it was stripped without you knowing it with no leaking of trans oil it should be fine with just a longer bolt.
Thanks for the suggestions. So you are pretty sure there would be enough room to drill it out to 7mm? If so would a helicoil work? Then I can keep the stock bolt and not have to drill into the slave cylinder as well. There just doesn't appear to be a lot of meat on the case and I'm afraid drilling it out might destroy the case.
Another thing a co-worker suggested was finding a welder who can weld aluminum and have them fill the hole and then retap it at 6mm. That would probably require I take the whole case apart though.
Anyone by chance used the loctite thread repair? I figured if I'm going to drill it out I could try that stuff first and see if it works.
Edited by Jackace
The stock bolt is M6x20. I bought an M6x25 on my way home today and it hits the threads but only gets about a 1/4 turn of good bite and sticks out a few mm from going all the way in.
If you can tighten to 25mm bolt I would shorten it to use without it bottoming. A 6mm heli coil needs the hole to be increased to a 1/4 inch I believe or 6.35mm    Should be enough case to do this. The heli coil kit should give these dimensions to be certain.
If you are confident in your ability Heli coil is the way to go. There is 100% enough room to go to 7mm but remember you will have to drill out the cover as well as you said earlier.
Never used a heli coil before but I went to the store tonight and got one. I will probably try that this weekend. From what I have read I should use some red loctite on it so it doesn't come out and hopefully that should hold. Just need to make sure I get everything straight. Go slow and don't get in a hurry seems to be the key.
Edited by Jackace
Sounds like a good plan. I over think things so be careful with the red locktite, it could cause the insert to come out with the bolt when removed maybe put a drop of oil or a little grease on the bolt.
Edited by jugnuts
I meant put loctite on the insert when I insert it. I won't put any loctite on the bolt.
if you look in their is a bottom to that hole and their is the possibility of blowing that out then having that scrap floating around between the centercases waiting to destroy your motor. i like the idea of run a bottoming tap then stud and stud locker compound
Heli coil is installed and appears to be working. I was able to tighten it up like the other bolts. We will see if oil leaks and it holds though.
Thanks for everyone that chimed in. I appreciate the responses.
Edited by Jackace
  • Like 2
