NEED HELP fcr conversion on drz 400 sm
I have this fcr. All I know is it's an fcr slant body. I'm wanting to put it on my drz 400 sm. Can someone tell me what bike it is off and also everything I need to get to make it work/where to get this things at?
I have this fcr. All I know is it's an fcr slant body. I'm wanting to put it on my drz 400 sm. Can someone tell me what bike it is off and also everything I need to get to make it work/where to get this things at? IMG_0114.JPGIMG_0115.JPGIMG_0116.JPGIMG_0117.JPGIMG_0118.JPGIMG_0120.JPG
It could be off a 98-2000 Yamaha YZ400F(I think 2000 was the last year?) Or a early 2000 KTM. It doesn't really matter, the parts all basically the same. Yamaha part are cheaper probably. There are a few ways to install , you will need the early 2000s "E" (not E33) throttle cables and intake boot. You will also needle the clamp for the carburetor side. Also you will I need a vacuum nipple that screws into 1 of the 2 holes in the intake. These are Suzuki parts. I think you p/n's for the vacuum nipple and clamp can be found in the FAQ's. I'm not of sure of the size of the removable intake bell on your carburator but again the " E" airboot could be used if it's the right size ( or you buy the E bell adapter). Another option to use the stock "S" air boot is to buy a bell from Sudco or Jets R Us. I don't know the part number off hand. If you give them a call they can probably help you out. Without knowing all your other modifications or location, you can either buy a jet kit for the FCR equipped DR-Z400E from JD jetting or a handful of jets from Jets R Us.
The main jet will be in the 155 - 160 depending on other modifications and elevation.
Pilot ( slow jet) 42- 45
Needle OEM DRZ400E (DPX) 4-5th clip down or EMN around the 3rd clip
100 pilot air jet. 200 main air jet. 65 starter jet. These are likely already in the carburetor.
Float level 9MM.
  • Like 2
Yeah sorry it's a 39mm. I know I'll also need to rejet it as I have the 3x3, k&n filter, and full mrd shorty exhaust. Thanks a lot for the replies. I think i have all the information I need!
  • Like 2
...........and the 2005 SM, the SM with the best graphics ever!!!!:thumbsup:
  • Like 2
If it's really gunked up and you need that elusive midbody gasket, let me know. Like ohio said, you can do the intake adapter and stock SM airboot, or use an E airboot, but you will have to punch a hole in it to connect a breather hose, I believe. I think your stock carb/airboot clamp will work if you go the adapter route.
E throttle cable - Motion Pro 04-0196 http://www.ebay.com/itm/222188915393
Head vacuum seal - 13685-29F00 http://www.ebay.com/itm/182320536336
Intake bell adapter - 021-216 https://jetsrus.com/individual_parts/021_216_su.html
Intake bell o-ring - 021-439 https://jetsrus.com/individual_parts/021_439_su.html
Kehin EMN needle - 017-262 https://jetsrus.com/individual_parts/017_262_su.html
Rebuild kit - 018-870 https://jetsrus.com/individual_parts/018_870_su.html
Accelerator pump rebuild kit -018-860 https://jetsrus.com/individual_parts/018_860_su.html
Edited by HansLanda
  • Like 2
