Compression help
Well I got a 2001 cr125 and I did a compression test when it was cold and hot and both read 120. Is this to low to keep riding or should I do the top end. And also with the low compression would that have an effect for oil leaking out the exhaust? Thanks for the help
try for oem, you also need to look at the condition of the cylinder and get it measured for a new piston.
Last I checked the aren't making OEM pistons anymore, or atleast that's for my 03 so I figure they also aren't for 01. I hear prox is an OEM copy though.
Okay well first I got to take everything apart and measure to see if everything is stock or not and I'll most likely go after market
