Big bore base gasket ,3 layer or single for more compression
It is personal choice and just by itself , you would be hard pressed to tell which one you had . If you want no fuss riding with most fuels then use the 3 . But , if you are looking at going for higher horsepower in the future go the single as it will compliment higher power . The only thing is you will have to use a higher octane fuel as the engine may knock/ping under load without it , greg
  • Like 3
If the question is which will increase the compression ratio then the answer is 1.
Otherwise I agree with answer  #1
Edited by Melkor
Damn autocorrect
