FCR Tuning Woes
Hello all,
I'm having a bit of trouble getting my 97 XR600R to run with the FCR. This last summer I had it dialed in pretty well (or so I thought) except for a hanging idle that would come and go. I tuned the idle per the FCR website but after finding the optimum A/F screw position I did have to speed up the idle a bit (turn it clockwise) to get the XR to start on the first kick more consistently. The choke was working correctly and the hot start knob was also working correctly. I thought maybe that was a good indicator the carb was dialed in? Fast forward to today and it's about thirty degrees cooler and I can't even get this thing to try and start. I understand that it's colder (air is more dense) than when I tuned the carb but does it really make that much of a difference? I decided to hit it with some starting fluid and I got it to run on the choke for maybe a minute before it just died. Kick for another 20 minutes or so and still every time it would start it would only run for a few seconds and then just die. I could raise the RPMs by twisting the throttle but when I tried to let it idle it just dies. I am almost certain my problem has to be the idle circuit but I am not sure how to start this process now that the bike wont even start or idle.
Carb info
Main- 160
NCVT needle third slot from top
Pilot- 45
Starter Jet- 72? Should be stock for a 2006 KX450F
Leak Jet- 35
A/F screw 2 1/2 turns out. I can slow the idle by turning it in (leaning it out) but I cant slow the idle by turning it out (making it richer). Doesn't that indicate a lean pilot?
Bike info
I am assuming the engine internals are stock.
I think it has a full e-series exhaust but I will have to post a picture to confirm the header is White Bros.
K&N Air filter cleaned and oiled before winter storage.
2006 KX450F 40mm Carb with 3D printed adapter for air boot.
Premium gas with sta-bil that's about 6 months old.
Any help is greatly appreciated.
Try turning your idle screw up some,,in colder weather it`s normal to have to adjust the idle screw up more until at least it`s fully warmed up..could be 20 minute or more depending on how cold it`s out..
B
B
Thanks for the reply. I did try this while I was out there earlier. I also experimented with turning out the A/F screw. Eventually I returned them to where I had them set originally. Today was about 45 degrees and I tuned these circuits when it was about 80 outside.
Drain the "preserved' varnish out of it and try again. Modern gas holds up about as well as a loaf of bread. Would you eat six month bread? :)
Yup, it's normal to turn up the idle speed during warmup.  And these engines do take quite a while to fully reach running temperature.
Also, you may want to readjust the idle mixture screw for the colder temps.  Remember to adjust only when the engine is fully warm.
Quick update. I think I'll try a richer pilot. I can't bog the engine no matter how many turns out the fuel screw is. I rode my drz400 with the same preserved varnish last time i posted and it absolutely ripped. Hasnt been started since fall either. I've never had problems with fuel going bad over the winter if I've used Sta-Bil. YMMV
