stubborn gasket?
i have to remove my gasket the one between the motor and the cylinder base before i send it off to get it bored out......is there an easy way to do this?
i was thinking of spraying it with soapy water or something to soften it up.....then take a razor blade to it?
any help would be much appreciated.....thanks
i tried doing it without soaking it and what a pain......
Don't use a metal scraper. You'll gouge your bottom end and cause a leak & that will cause a hell of a lot of problems.
I don't know about the hot soapy water but you should try a plastic scraper.
Just now, joethumper said:
oh man i did use a razor and gouged just a 1/4 inch of area......shoulda waited
whoops! hopefully you don't have to replace the whole crankcase...
it was on the cylinder base.......but i didnt go all the way across the area just the edge got mucked up and not too bad
oh, well hopefully you'll be alright.
