FCR39 Rebuild Cheking My Math
I am in the processing of pulling my FCR39 and giving it a full clean after sitting all winter.
Can you please validate my jetting is correct.
Minnesota 700 above sea level.
2013 DRZ 400SM 3X3, MRD full system, K&N filter.
160 main jet
200 main air jet
EMN needle
clip 3
45 pilot jet
Stock FCR pilot air jet
R&D Racing Flex Jet Fuel Mixture Screw 2 1/2 turns from closed
o-ring mod
Thanks for the help.
Looks right, but each carb and bike varies.  Tweaking on the fuel screw may be needed, and verify your AP is working correctly.
How does it run through the range ?
You could go slightly leaner on the main , i got better throttle response with a slightly leaner needle ( the next needle down from EMN )  .
i am talking only slightly
I bought a used air box cover and added some small vents too , again .. crispy throttle response
my elevation is around the same as yours , but variable due the the hills .. Here ( Down Under )
Thanks guys.
The bike is strong through the rev range but not very steady at idle.
try screw at 0.5 from closed.  better or worse?
fcr-mx with 100 pilot air jet usually needs a needle with leaner root diameter or at least a smaller pilot jet. emN needle was perfect for fcr slant body, not for fcr-mx
On 3/29/2017 at 8:48 AM, rraiderr said:
Thanks guys.
 Fine tuning your fuel screw should sort out the idle
why is the stock 80 air jet not used , i see 100-200 air jets are very popular !
im interested in this !
Stock is 100 pilot air jet and 200 main air jet
Great to hear from you Craigo, hope everything on you end is awesome.
I may the other needle.
My fcr slant came off of a stock E Drz and has a 80 air jet , I guess I should put a 100 in its place ? Why would someone Change it ? I'm Curious
Thanks for the reply craigo
US specs maybe a little different to the rest of the word...What pilot jet has it got ?...I am guessing a 42 if it runs a 80 paj as stock
Yes I believe it has a 42 pilot
I have a 45 sitting here
California 0-4000 ft elevation
Jd jet told me to leave the 80 air in it and follow there directions in the kit ,
I see everyone has emn needle 160 main 45 pilot 100 air
With great results
