Big bear 400 oil cooling element
My oil cooling element for my 2000 big bear 400 has a crack in it.  these things are so expensive to replace.  This atv has sat for 15 years and there are a lot of expenses already in fixing it up.  My question is, is there a way to fix it, weld, solder, ext.  Do they make an epoxy.  If you look at the pic you can see the pic at the bottom. Whats the best and easiest way to fix this. Please help
Edited by scb41681
