Atc 185 crank same as xr200 ?
Looking  for  a  crank  to send out  to have stroked.Atc 185 and 200 engines  are  very  plentiful  and cheap.No luck  finding  an xr200 engine    yet. Will the crank  from atc185/200 fit xr200 ? Thankyou
Not the same. Clutch end and flywheel ends are very different. Look around for an XL 185s crank. Same as the xr except for main bearing on the flywheel side being slightly larger on the xr which can be fitted to the 185s crank.
