'16 XT shifter oil seal replacement
I nailed a rock and bent my shifter on the last ride. After finishing the ride, I noticed an oil leak had started from around the seal. A couple of questions:
1) What are the chances I bent the main, internal shifter shaft? I tried to manually bend it back in the field, but stopped after having to pull too hard, but not hard enough to straighten (or even re-bend) the shifter.
2)Could I have distorted the oil seal without damaging the shaft?
3) I'm hoping replacing the seal will fix it. Any tips or How-To's on how to do this?
4) I'm guessing/hoping I can find the seal at a bearing shop. Is this reasonable?
Thanks for any input.
All of that is possible.
Don't waste your time looking at a bearing shop to save a couple bucks, make your life easier and just get the right part.
Unless you don't live near any motorcycle shops.
If the Beta dealer is too far, try a KTM dealer if they have a good tech/sales guy who is willing to check if a KTM seal is the same.
