Need help Identifying Carb
Can someone identify this carb and tell me what size it is? It has a 48mm bolt pattern and I believe it is pz20 clone but I'm new at this and need help.
And also whether this carb worth rebuilding or if I should just order a new carb? If you think I should just get a new carb could you please recommend the correct size for a '70 CT70 engine?
It is the ShengWay 20mm carb that TrailBikes and T-BoltUSA sell, it is made in Taiwan, replacement main and pilot jets and a rebuild kit are readily available for it from either of the above.
