99 yz400f crank discoloration
Apon removing the jug on 1999 Yz400f found blueing on the crank. It is more wide spread on the clutch Side of the motor. Is this a common occurrence or do I need to be shopping for a replacement
The factory uses heat to ease the insertion of the crank pin and alignment.  Every YZF crank is like that.  The bearing could not generate that much heat without 1) turning the big end of the rod black, and 2) failing completely.
