Cam chain tensioner question
I removed the tensioner bolt from the bottom of the left case and the spring popped out.  I reinserted the spring and the bolt.  Is this fine to do or do I need to pull the flywheel and stator cover to ensure everything is proper?
It's a 2003, so a bit different, but I was sure to put it back in the same way.
