MADS easy way of disabling the kickstand safety switch
Easy disable kickstand safety switch
I found an easy way of disabling the kickstand safety switch so that when in gear you still see the kickstand light on on the dashboard if the kickstand is down, but the motorcycle will start.
I use one of the following quick splicing connectors:
zir1XRxApAb-POc0yBZDv6mrpKddJBobHv-Uz6ZW
These splicing connectors have a plastic stop in the middle of the rear channel. Use a knife to break that stop out so that you can feed 2 wires in parallel, one in each channel. On the kickstand side of the green connector under the seat, insert the green and green-and-white wires into the connector and use pliers to push down on the metal blade. Close plastic lid. When done it should look like this:
qAsrPHxTyQaPlCNGHe_3TGLfOBHbKYbLZQLCaP17
lkbDVehP73zAATfuxkggkeZxCjZHGBCL-cauR1HS
Here is how it works:
31 minutes ago, TimeToStartRidingAgain said:
My question is where is the kickstand down warning light?
I don't have one.
On my bike it is the orange light (S) to the right of the (N) neutral light.
cuDMzgbIwmIrxF_qGzoawxk4rbud12VhjTd9fzb-
13 hours ago, TimeToStartRidingAgain said:
I purchased my L brand new and that light never worked....wild
You bought your bike new, I was wondering if your bike came with a tool kit, I just bought my bike new and it did not have one.
I also just bought a 2017 new.  Seems they do not come with toolkits anymore.  That is really cheap of them!
No tools.
Lame manual.
That yellow light I just assumed was some sort of warning light that would come on if something went wrong...sort of like a warning light in a car does.
Kickstand up or down it wasn't lit up though.
05 XR650L bought brand new...No tool kit. Don't feel pregnant.
phffffffttttttttttt   you guys shoulda bought an 01   my bike came with the kit and a working kickstand light...
NEWER ISN`T ALWAYS BETTER..
:lol:
B
My '05 came with a tool kit , not that the rubber wrenches are anything to brag about.  :smirk:
