2013 crf450r clutch in a 2010?
Looking for some advice for a buddy with a worn out 2010 crf450r clutch. I have a 2013 and replaced my entire clutch with a rekluse core exp. my question is I know the baskets are the same for most years of 450Rs, is there any reason the the hub from my 13 wouldn't fit his 2010? I assume it would but I don't want to get in there and find out it's not compatible. I assume if the hub fits, then he can use my 6 spring pressure plate and 13 steels and fibers for a decent upgrade over his weak 4 spring setup. I know someone on here has the knowledge so figured I'd ask. Thanks
I don't believe they are compatible.  The 09-12 models are different then the 13-16 clutch assemblies.   I have a 6 spring Hinson unit from my 10 I was going to sell since I'm looking to upgrade to a 17 model.  Send me a pm if your friend is interested.
They changed the spines on the inner hub on the 2013. I think they changed it back to the 02-08 splines.
If he finds a 6 spring inner hub from a 09-12 the other part s will work.
all 9-12 450s hondas are 4 spring, changed back to 6 in 13, so its a no go.
polishhammer hit the nail on the head. the splines are different
