Help me !!! Won't run right
OK so let me sum it up I have a 06 450x it has new valves and a tune up at Honda the bike is running a powerbomb header and a 4.1 silencer the bike won't start unless I take hours to start it it just isn't jetted right I believe I've owned it for 3 years and it was never jetted correctly the carb has some mods what's your jetting suggestions? Jd jet kit ? I havn't done the air box mod is it worth it ?
Before you start with the mods, get the bike to or specs and properly running, now were you having those problems before you took it to the shop to do the valve work?
When it does start it's with the e start it's never liked starting with the kick valves were getting cooked I guess it's been awhile
I believe your problems have to do with proper timing, valve clearance, proper jetting and carburetor service. Plus try a different shop, seems they are wasting your time and money.
