drz400s 2004 with an oil leak...buy or not?
Hi,
newbie to the forum so hi to all!
went to see a drz400s over the weekend as a first bike. It rides well, no fumes, suspension ,clutch, brakes and gears all ok. It has 10kmiles and is a 2004. My issue is that it has an oily right side and front side on the cylinderhead and even showed fresh oil on the(wiped..) top side after 200m riding..pictures attached.
Should i buy or walk away? Your opinion is appreciated!
Joris
What is the price?
There are 2 breather hoses on the head that can seep oil over time. The cover also has seals around the 3 bolts what could leak also.
While the problem is minor and simple to fix, it shows a lack of attention by the seller and makes me question what other issues they are ignoring.
Fair point. He wants 3100USD for it and will include some extra tyres and a larger fuel tank.
Great! Thanks! Yeah i recon its worth a lot less than what he asks for. Basically its been ridden off road mostly and due to the age , bushings and rubber stuff starts to leak. I am only wondering if i will run into a bike that will eat a lot of cash straight away of if i could fix it with some TLC and good maintenance. Clean up the bike in small steps while riding so to speak. Any budget to put aside?
Ideally a good used bike purchase won't need a bunch of replacement parts. That said, the most commonly neglected parts that often require replacement on used dirt bikes are the chassis bearings and suspension components(fluids and bushings)
Agreed! Likely more issues that are under the radar now. Thanks for the inputs! Joris
