Gas tank
I put the IMS tank on. Itfits fine. The shrouds will need to be trimmed very slightly. The left shroud goes on tight but no problem. IMS 2.6
I also put the JD tuner on.
  • Like 2
Where did you mount the JD Tuner?, and did it come with a good pre-programmed map or did you have to mess with it?
I mounted the tuner under the seat right on top of the rear fender in that little void. The tuner comes pre-programmed with their settings. You can set it for stock or tume yourself. I found that I had to increase fuel down low so my settings are richer tan what they sent with the unit. Im very happy with it.
