Clutch Lifter Plate, Cam Plate, Clutch Ball Retainer Install
I pulled the right crankcase cover off a 2003 XR50R and a few clutch components fell off as I was removing the cover.  Are these components supposed to be held on by the cover or is something wrong?  I noticed the bolt in the center of the cover, but I didn't remove it (because the service manual didn't say to do so).  This bolt is aligned with the components that fell off after removing the case.
If you are referring to #4, 5, and 9 then yes they will fall off when you open the right side.
Here is how they go back (disregard the red arrows):
Is the hole in the center of this bearing supposed to be offset like this?  Kind of looks damaged to me.
Okay.  Just wanted to be sure because there were no dowel pins when I removed the cover, so I was thinking maybe it got worn down unevenly over time (because the cover shifted).  Plus the off center portion is shiny and rough looking like it has been worn down.
There is what is called an oil through and spring (parts #10 and #11 in the link below) that goes inside that from the front, you can see it in the pic that CRF James posted. It looks like a dowel pin but has a slightly closed end to keep the spring in place.
External clutch parts
I have everything back together and the bike started first kick :thumbsup:.  However, I have small oil leak coming from the clutch adjusting screw/nut on the right cover.  Appears to be coming from between the screw and nut (as opposed to the nut and the cover).  Is there an o-ring or seal that needs to be replaced behind the cover?  There was a flimsy piece of rectangular shaped rubber behind the nut and that was it.
For reference:
Now that I'm looking at the diagram, is there supposed to be another small cover surrounding the clutch adjustment nut?  The bike I am working on has  what appears to be an aftermarket carbon fiber cover which is held on by the clutch adjustment screw lock nut.  Perhaps this is the reason I have a leak.
Edited by mossman77
That flimsy piece of rectangular rubber is your o-ring. It goes under the nut and washer. Part 15 in the diagram. Part number is 91306-HB3-003.
There definitely isn't an o-ring or a washer, but rather a makeshift seal.  I'll replace it with the proper parts.
Edited by mossman77
Does anyone happen to have a pic of the washer and o-ring?  There isn't a washer in the gasket kit, but I have a few o-rings.
I can take a photo when I get home tonight. It is an odd shaped o-ring. Instead of having round profile, it has more of a triangular profile.
No, that is a valve guide seal for the older Z50 models. The size for the o-ring is 8 x 1.7, if that helps. There is an 8mm flat washer that helps hold that o-ring in place
Given that the oil is seeping out from between the screw and nut as opposed to the nut and cover, does it sound like I should replace the nut and/or adjusting screw as well?  You can clearly see how rusty it is.
Edited by mossman77
No, you can clean up the nut and the adjuster stud on a wire wheel. the thing to do is ditch the carbon fiber cover and put everything back together.
1 hour ago, CRF James said:
You still need a photo? I am home now.
Sure.
