Hinson clutch basket torn up/ dont use philips head.
10 minutes ago, grayracer513 said:
Pretty pictures.  You broke off that fourth Phillips head (which likely didn't belong there) and ran it through the works.  Is there a question here?
No it's more like a what not to do if you have a Hinson clutch. I got a bike that had it and eventually gave out. Should probably inform to not use philips heads as a replacement.Which i don't know why they didn't just stick the manufacture screws in.
all of that damage is cosmetic. put the right bolts in, torque/loctite, and ride !
I would want a closer look at what is happening in picture #4.   It shouldn't be too hard to make that case seal again.
