2010 300 kickstarter issues
hay new to this site, not sure if this form is where I wanna go for the exact answers I need but ill give it a shot. I have a 2010 300 xcw and the kick starter always skipped a little bit but its progressively gotten worse. so I ripped the side of the case off to inspect all the gears and meshing and realized every gear looked unscaved. no missing teeth or shavings, everything looked great. So I'm guessing its gonna be the spring that pushes the kickstarter mesh together has weakened. Just wanted to know if anyone has had this problem or know of anyone talking about it. If so I'm interested to know about this issue
        thanks Ryan
I have had problems twice on the older design.  This design uses a ratchet gear and a spring.  I'd replace both and inspect the mating gear
I inspected every tooth on ever gear and they all looked in pristine condition, but I will try new ratchet gears and a spring. Thank you for you time much appreciated!
