2015 YZ wheels into.. 2016 17 WR??
Any thoughts on that??
I've had this set now for almost two years in anticipation of the new WR..
However..
After reading some posts:
I'm not too sure if these would make it onto the bike..
front axle on the yz has 25mm and rear 22mm the wr front 22mm rear 20mm..
would it work to alter the bearings??
or...
32672937-Funny-garbage-bin-for-recycle-S
thoughts anyone??
Edited by patrick2wd
Front on the WR/FX is 22mm, YZ is 20mm...as far as it's known no bearing with the correct outer diameter of the YZ hub and the inner diameter of the WR hub work... There might also be the speedo issue too...
The rear is a 25mm, your rear is 22mm and as far as known no bearing with the correct outer diameter of the YZ hub and correct inner diameter of the WR exist.
In short you are SOL...
