2012 kx250f sff forks wayyyyyy too stiff???
Have a 2012 kx250f with the sff front forks I can barely get the front end to move on the bike, it is rediculous how stiff it is any input would help don't know if bad bushings would affect this or what... thanks for the input
How about a video or something?  Stiff is subjective.  Hard to tell if there is a problem or not without more information.
I got them tore apart already but I weigh 200 pounds and if I throw all my weight to the front end, I maybe get a inch-inch n a half of movement, now when I tore them apart the nut that's on the bottom of the fork leg that holds that rod that goes on the inside of the bottom fork leg together that nut was loose idk if that would have anything to do with it or not
And that rod was slopping around inside the lower fork leg, should that little rod be completely stiff?
That sounds bad.  Is the rod screwed up?  Threads still good?  Any metal debris in the fluid?
That should make them softer
