2017 FX 450 melting side panel
Hey guys, I just picked up a 2017 FX 450 about 10 days ago and I have 11 hours on it now, I'm a B class hare scrambler and desert guy. Anyway, part of the deal was the bike came with the Husqvarna FMF 4.1 ti with carbon tip slip on, I just raced a 100 mile desert race and my side panel is melting where the slip on meets the pipe. I think my boot must push the plastic into the exhaust a little. Has anybody else had this problem or know of a fix? I have not run the stock exhaust on this bike, but I thought that with it being a factory pipe I wouldn't have this problem. It looks hideous
Thanks
Yes. Common problem. I roasted mine and my Tech10 Boot.
My dealer replaced my panel under warranty. I did modify the mount with a stand-off to eliminate the problem recurring.
is there no heat shielding on that panel?
The heat shield is barely thicker than a piece of foil- about 1/8 inch.
I think KTM designed this with the Euro map in place, and did not anticipate the extra heat from the NA debacle.
Filipe, I like your spacer idea. what did you put behind it? I will talk to the dealer and get a new side panel coming.
Sorry for the delayed response. First week at the new job and it's kicking my azz.
Here is part of a thread where I discussed this with some others:
I used the EZ coil from Pep Boys. It's working pretty good.
I also extended the bolt holding on the right panel out about 1/2 inch by lengthening it and adding an aluminum sleeve between the panel and frame.
I also wrapped the header right at that point with heat tape.
If you ride hard and grip the bike with your boots, it's gonna melt. I just ignore it.
double up on the foam/foil shield that comes on the panel. about $3 and creates enough room to prevent melting
  • Like 2
My 2017 FC450 melted the side panel with the stock exhaust too. I used header wrap and stainless zip ties to keep from melting my boots. The new side panel should be in soon and I will keep the header wrap and double up on the foil heat shield.
Thanks
Does the stock FX head pipe have a welded on bracket with a round rubber piece under the side panel like the FE's? If yes, very carefully bend it out to give your side panel a little extra clearance. And did they re-map your bike for the FMF? It may be a bit lean causing it to run hot.
