Clutch kit recommendations?
OK so I am getting ready to do my SE kick-start conversion. I finally found a working link to the German walk-through I have always heard about and two thing came to my attention. First is that I am missing 2 parts I never knew I needed, The kick idle gear and a bushing for said gear. so I am in the process of getting them before I start the tare down. Second and more important that I have to disassemble the clutch to install the idle gear. Since I have to essentially rebuild the clutch already I might as well replace it while I have it apart. Which Leads me to ask for recommendations on best clutch for the money. I want stiff springs, the stiffer the better. I have a very strong grip and I am not worried about a hard pull. Lastly, I have read that you should always replace the clutch cable when you do the clutch is this true? What are the must replace parts that you usually need when rebuilding a clutch?
OEM for clutch discs & springs.
a new cable is smart also.
usual parts are the discs, hub nut lock washer, cover gasket & 4 sealing washers.
but once inside, close inspection is recommended for other worn parts
