48 Tooth Rear to a 50 Tooth Rear
Changing my gearing up a bit.  Going from a 48 tooth, to a 50 tooth.  Think I'll need a new chain?  Chain tension is just about right, and its set about right in the middle.  04 CR250r by the way.
I'm 99.9 % sure you will need a new chain.
In case you are interested,
On my 05 CFR250R I'm running 13T/51T and I replace both sprockets and chain at the same time then CAREFULLY measure the new chain before removing the correct amount of links. MEASURE twice, cut once and make sure you cut at the right link :)
Edited by filterx
