Shock bottoming control?
Is there a way to help shock with bottoming without making whole thing harsh?  I am noticing tire marks on my fender and exhast
It's normal unless excessive
My LSC is max stiff now so I need to add probably 2 base shims anyways to get clickers in range.  Guess hsc would be bottoming huh?
If you add shims to the low speed stack you will be increasing high speed as well ( good in your case ) you should be close to centre on clickers
