rear shock
Hi all, just recently bought a 1999 xr400. I'm relatively new to dirt riding so I need some advice. Can someone help me determine what this is attached to rear shock? I know it compressed air but not sure how to use it in adjusting my sag. I've tried to look it up online to no avail-can't make out the name/brand.
thanks for any help you can provide.
That canister on the side of the shock body is a nitrogen bladder,
in no way it is used to change sag height.
Usually pressurized in the 140-150psi range, it keeps the shock's oil from cavitating.
(oil separating / creating air bubbles as it passes thru damping orifices)
Worth having it serviced, bled and re-pressurized,
over time the nitrogen gradualy migrates thru the rubber bladder into the oil,
can happen in less that 6 months even on brand new shocks.
Sag is done by adding/removing preload on the spring,
proper settings are only achieved pending you have the correct spring rate to match your weight.
Edited by mlatour
