Honda
I have a 2001 honda xr200r that just got a fresh top end rebuild. I've cleaned the carb 5 times re-timed it 3 times including checking valve clearance and it does not run properly. I've even noticed it blowing out exhaust or air through side of air cleaner. Any idea on what's going on?
My first guess would be that the Timing is off.  Double check your Timing Chain installation.
Yeah, I took everything off, the cam out re-put on the timing chain lined it up perfectly, timed the pulse generator, check valvr clearance, checked started decompressor put it back together and still does same thing
