'14 690R MIL 17 code
One long-seven short, lambda (O2) sensor circuit fault.
Bike has 3000 miles, FMF muffler, EVAP canister removed with resistor, TB vacuum capped.
Bike would often stall on cold start up and idle. It doesn't appear to be doing that anymore. Wasn't a problem, restart.
Now it's throwing the code (instead?), same cold startup and idle. Rides fine. If I turn off and restart the code goes away. So still not a problem.
Just curious, guessing the sensor is going, or could I have a fueling or some other issue? Bike runs great, nice linear throttle response.
